The new LX has a bit of a squeak when applying the brakes, so I picked up some front pads (rear will arrive tomorrow), changed both front sets in about 30-40 minutes. When replacing the front right, I found they were worn a little more, but the most worrisome thing was, that one of the pads had been put in BACKWARDS. The friction material was against the rotor, but the pins did not go through the pad as the holes were oriented towards the hub, so the pad was "floating" in the caliper, but the pins prevented the pad from falling out thankfully. Now the squeak is gone
Also had the leaky replacement cats rewelded in, no more pshhhhh while driving
Lastly, I added a cargo power point. Went from batt to 8g wire to 40amp circuit breaker, then to 8g, thru the firewall on passenger side, along the rockers and behind the rear passenger side cargo panel. I drilled into the little storage compartment, and continued th 8g to where I mounted the 6 position fuse block, then went from the fuse block back out the storage compartment w/10g to a led lighted switch and then to the cigarette style power point, 10g ground to body. the power point and switch are mounted next to each other on the cargo panel, just below the vent thingy. Now I have constant 12v power which can be switched on/off with LED indicated switch. I put the Norcold 30q back there and my H20 and beer are getting cold as we speak!
