Why dual batteries?
What purpose is served by having dual batteries?
Improved winching capabilities
Allows for extended 12V accessory use while camping etc...
Provide redundant starting power supply
Takes some of the pressure off of the alternator to keep up during shorter duration, high loads.
Most people are using more electronic today than what the system was designed for. Lights, winch, cb, computer, airpump, cell phone, fridge, ect. easier to keep up with high demand and can help you if you forget and run one down. I have also been able to help someone else with a bad alt get home by switching out batteries with them and charging it while going home. Inexpensive piece of mind
The 80 series does not have a particularly strong alternator (80 amps?) Compare this to modern 130 - 160 amp alternators being used in 4 x 4's.
Allways was the same history, the FJ60 came with an alt which provided less than 60 amp when the others had a 95 amp.
Anyhow I trust more in a 80 series alt than the others 130 - 160 amp unless they are made by Denso.
Of course when you add a second battery then a 80 amp is not enough to fast recharge both.
because you can't push start the automatic
Neither a manual, on a foot deep of nice and goey mud :grinpimp:
But it would be nice that the one who will pull you out with his winch, carry a double battery :)
Wife was caught with a dead battery. Had to wait for over an hour for AAA to get there. I don't want to put her through that again. It was a bad area and she was panicking. With a dual set up this scenario no longer occurs.
