I've got 150 amp sequoia alternator with smaller pulley and beefier cables. Shouldn't I be seeing 14.0 volt? How do I troubleshoot? It fluctuates from 12.9 to 13.7 right now in normal driving condition.
Thanks
Thanks
What is the voltage at the battery using a DVM at the same time being displayed in the Scangauge (at the same RPM)? There may be an offset between the two.
With a fresh battery I saw different reading as well with my Scangauge II. Always seems to show higher (around 14v) when I first get in the vehicle and lower after a long drive (mid to high 13's). I haven't seen anything in the 12v range though.
That is the way it should work. The voltage will vary depending on; battery charge level, system demand/loads, motor RPM, etc.
Example: When the rig has sat, then started, a big load/draw is placed on the battery, the alternator has to deliver to replenish the battery and cover system loads, once the battery is topped up, it only has to deliver enough to cover system loads. This is handled by the regulator, it controls alternator output to meet demand. For the most part, alternator output is relativity low, if it ran full bore all of the time, would quickly smoke the battery.
Yeah can't do chop chop...these days I'm doing good trying to keep up
Got home from work, got the DVM to the battery and I got 14.0 like split of a second then it stayed between 13.9 and 13.8 with AC and my electric fan running at full speed. So what does that mean? battery needs to recharge? Or I have a parasite in the system?
