After advice on whiteline swaybars to stop body roll .They make a extra heavy duty rear 30mm and hduty rear 27mm..and also extra heavy duty front 32mm..just wanted to buy one to start with..should i get rear or front? what do u think.
Whiteline's HD will, most definitely, reduce body roll.
It is critical however knowing whether you have accessories (Bullbar, winch, rear bumper with carrier...). The bars you choose must be tuned to the overall weight of the vehicle, otherwise you'll most likely end up with a harsh, unpleasant, even unsafe ride-should you run a “light” rig relative to the sway bar.
thanks for the response, something I would consider in the future if my center of gravity goes UP at all, right now I am only on 2 inches of lift which is probably why my stock sways work fine.
yup, just recently replaced my swaybar bushings all with urethane, noticed a big difference on corners after this, before the rubber was basically falling out.
