White smoke?
Sacramento, CA
Today I was just cruising down a road about ten minutes from my house when I noticed a plume of smoke behind me. I pulled over and turned the truck off. turned it back on and smoke came out, then stopped, and would come out when I pushed the gas, then stop when I let off. Start driving home after no smoke comes out of the exhaust while pushing the gas, and now the truck backfires at high RPM shifts and then a plume of smoke comes out right after. I'm thinking a seal somewhere (obviously). Don't think that it's an O-ring, or else the smoke would be constant, right? Any ideas?
cool, well, that I know what it is now. When I replace it, should I replace other things as well? Piston rings? Anything at all?
I would pull the head, check the block deck and head for straightness and provided it looks good, replace the gasket and get it back on the road. If it's the original hg - it may have just been it's time to go. If you start removing the pistons, rods, etc - it's gonna turn into a complete rebuild and the rig will be down for a lot longer than you originally anticipated. Good Luck
this can also happen when you haven't driven your cruiser in a while the carby just needs time to clean itself out. it could be your running to rich. i have a camaro that did this. it cleared up whenm i drove it more.
if it was an oil problem the smoke would be blue or purple.
brian said:
head gasket or less likely cracked head.
white "smoke" is coolant.
get it now before it creates larger problems.
or your right it could be this too
Do a leakdown check on the cooling system. This is when it is pressurized, and then you watch to see if the pressure drops. There should be no significant drop. A leak will generally drop immediately a few pounds and then level off, or drop quickly and keep dropping to zero pressure. This test is run with the motor off.
If the pressure does not drop, or drops over a very long time, then suspect bad gas.
If you don't have the tool to run the check, most good shops can run it.
I have had blown head gaskets on several occasions (my curse). It is usually the result of overheating that warps the head. One of the things that always happens to me is that exhaust gases escape into to the cooling system and build up mad pressure and heat. The cap on the overflow reservoir usually blows off and exhaust bubbles in the radiator. It is all bad but any easy fix with a trip to the machine shop and a new gasket. Of course, you must seek out the initial cause of the overheating and correct that as well.
if you find a bad gasket take your head to a shop that can magnaflux your head or whatever its called they will check the deck as stated above and you might as well change the seals and check all the valves the whole process around here is no more than 200.00 .
