Which springs?
Beech Bluff, Tennessee
My wife's 1997 with stock suspension feels too spongy. Going to make it her daily driver/kid hauler. I want to stiffen the ride a little. Don't really want to lift it. An inch or two would be OK.
So which springs would be my best bet? What is a good close to stock height spring with a heavier compression rate than stock?
What options out there for stock height non heavies? Stock Toyota springs are no longer available for all 4 corners.
There have been good things said about the TJM 50 mm progressive springs and Fox 2.0 shocks combination.
I believe that the OME stock height replacements are pretty stiff if there's no extra weight (bumpers, rack, winch, etc.)
The ride quality on these is awesome, but they will provide 2-3" of lift unloaded.
These springs are dual rate, which means there are a few coils of a softer spring rate, 160lbs if I recall, and it's not until you compress all the softer coils that the heavier spring rate sets in. So it would actually ride pretty close to stock until you put a bunch of weight in it, then it would ride like heavies. IMO, this is the best setup (and pretty much the only choice) for someone looking to haul the kids without much lift.
I 100% agree with Heckraiser... also get the factory OEM shocks. They have the best ride people say plus cheapest option. Contact @beno for the shocks.
Stock shocks with 2.5 inch lift?
Pro comps have a better ride than oem ....at $35 a pop is the cheapest solution
Fox will do a better job though for the price..if you get the fox shocks, get the 3"-5" sets as they come a little short for the recommended lifts.
Stay with Ome springs
Yes. The limiting factor in that case is the length of shocks when compressed. Unless you put extended bump stops, you need to run stock length shocks. If you go with taller shocks, it will bottom out on the shocks instead of the bump stops. That will ruin new shocks with a quickness.
Is this worded right? Seems counterintuitive?
You need to go with slinky/icon. It's the only real option anyone has and you can just trim the coils to the height you want.
  • Like
Reactions: Nay
