Which holes belong??
BOISE, ID
Can you guys tell me if all the holes circled should be filled in? 99% sure of all except the two closest to the doors.
a
None of the holes you circled are original a 40.
Lol, while not original, I’ve seen several of those Indian motorcycle map lights mounted in the same vicinity, usually below the ashtray on early rigs without the dash pads, I think in the hole intended for the cig. lighter. Always a curiosity to me, if these were dealer installs or a cruiser club somewhere that had a number of their members do this mod. I’ve got one in my ‘63, temporarily installed right now (not wired up) but I also have the Vader light mount location on the underside of the dash, no $1000 Vader light though 😂.
I’d be curious to know as well but probably will have the hole filled. What is a Vader light? Tried searching but nothing came up
It is just a slang term for the map light.
OEM:
Darth Vader:
Believe that is actually a 3D printed cover. Have a few of the and look to be stamped out of steel, smooth not rough.
Originally this were mounted to the bottom of the dash. Standard equipment back to the FJ25 at least. In the mid sixties in the factory heater became a option and then in 66 standard in the US market. The controls for the heater were on a bracket bolted to the bottom of the dash where the Vader light mounted. Curious if this was the reason why so many of the Indian motorcycle lights on dashes of the mid sixties on cruisers. Once the 68 model with the padded dash do not see to be as many. 68 the under dash Vader was gone. FST models had it next to the glovebox door. 72-74 all models either had the light or a plug where it would be. During these year all models had footman loops in the back corners.
Need more help with another hole. Can you guys tell me if the hole on the floor where the gas tank sits is original? Looks a little odd to me.
