I have disk brakes on all four.
Yes but it'll take more than just discs on all four corners to keep 4.5 ton straight if something goes wrong at higher speeds.
What is the max realistic speed that you need to travel? 110km/h?
The people I knew with 45 series landcruisers drove them at 80-90km/h max. They were a noisey handful past that.
The max speed and your patience on inclines will determine how much power you need. Drivetrain limits will determine what you can safely use.
There are very good reasons truck engines are built with a torque curve that peaks early and tapers off. It gives max driveability and keeps the drivers changing up. The average 4.5T 4x4 truck in my country has about 150hp and are geared for about 100km/h max, they'll do that for at least half a million km and many are built into offroad campers:
NPS450 4X4 - CAL Isuzu
DC version here: https://www.isuzu.co.nz/content/dam/isuzu/oc/nz/en/index/specs/n-series/NPS450C-Crew-VL24-v2.pdf
You would need to get your fuel pump properly tuned, bigger elements etc. It’s quite easily double the power of the 12H-T.
Yes but how long will a 12HT last at double the power? How long will the drivetrain last with double the power? Can you keep it cool under sustained load with that power?
Upgrading a heavy tourer isn't just about hp/torque numbers. It's much easier to blow up engines and gearboxes in heavier vehicles than the same hardware in a lighter one.
Best to pick a safe power/torque level for the existing engine/driveline and build to maximise driveability on it.
I know a guy with a twin turbo version of the 3208 in an old Chevy Suburban 4x4. He's been driving it for about 30 years and loves it. My BIL has an 1160 in a Firetruck he converted to haul his antique vehicles cross country. The 1160 is not very impressive. Cat still supports them though. Something to be said for that.
The 40 series doesn't have the room for the engine, turbo, radiator, intercooler and air-filters needed though. Fitting in a whole new driveline will be the next challenge. Same for the 6BT. You're not just fitting the engine.
Cummins R2.8. Hell no.
