which booster combo to use?
Lancaster, CA
Hey everyone,
I'm putting disc all around on my 45 project, but I know I'm going to run into fitment issues. What are people doing for this? I've attached a few pictures of what I have to work with.
thanx,
Craig
Not to put too fine a point on it - but did you use the search function or go to the FAQ's?
Given how your throttle cable is setup, I'd either go 80 series with no booster or a hydraulic booster. I've not seen many hydraulic booster conversions done on a Toyota, but they do work awesome and take up almost no space.
This link is a really good place to start.
You will notice that @Vae Victus has a different intake manifold than yours. It is smaller, tucks in closer to the head than yours.
Since you are running a header, swapping intakes is an option you can consider. It greatly increases your odds.
That said, Scott was not able to get adequate clearance for his 2F carb, and as his thread indicates, an F carb provided the final piece to the jigsaw puzzle.
Mock up the adapter with your booster and start taking measurements. We will go from there.
Doing a little more research, I see where some folks have put in a later year pedal bucket and taken out the welds/old pedals. Of course I see a mention of it, but no finished pictures of it done. Does anyone know how much that will move "things" over towards the fender? I really don't want to start swapping out carbs, intakes, and what not.
