Where is my.....
Virginia Beach
Coolant going. It started out that my A/C stop working. Initialy I thought is was my belt not being tight enough due to some trouble shooting on another part on my engine. Well after some thought I decided to check my radiator. It was a little under a gallon low on liquid. Bought some toyota red and filled her up and added some water. Now the A/C is running cold but I know there has to be a larger issue. Some history for my area, the issue started when temps reached in the 112 degree F. Last week was above 100. So I am hoping with some real doubt that the water has just evaporated and praying it is not the head gasket.
Mileage 172+
1994 w/ lockers
Pesky Heater Hose? (PHH)
Shouldnt evaporate out of a closed system. How does the oil look? How does the exhaust smell?
Burning coolant has a very sweet smell, unmistakable.
Did you check all the hoses for leaks? Check the radiator for leaks as well, mine was leaking on the seam where the tank attaches.
HTH
Daisy
How do the hoses look? Perhaps a loose or broken hoes clamp.
How about the engine oil?
It might not be a bad idea to pull the plugs and take a look.
A search should yeild several good additional trouble shooting tips.
Good luck and keep us posted.
What would I be looking for in the oil and the spark plugs?
As for leaks I can't find anything, looked last night and didn't see anything that was not there before.
I had the same thing happen to my 94. I too thought it was my head gasket going at a slow rate. Turns out it was my radiator, the top pitch area had a slow leak. It was barely noticeable until it ready started to let lose. This had been going on for a about a year until it started to drip enough to see it.
Is that in the right hand corner as you are looking at the vehicle?
top tank of the rad behind the foam (if its still there) seems to be a recurring problem, mine started going just like newps's after ~220K miles. could smell it occasionally for a month before the first signs of coolant showed up; the top tank was brittle and started cracking, probably spurred on by my leaning on it while doing PM stuff. CDan to the rescue- all the hoses and RAD etc were around 5 bills FWIW.
and Newps, you meant top pinch area I assume?
Guilitto- my whole top tank was cracking, like this; my foam had long since disappeared.
If the engine oil is contaminated with coolant it can have a light brown foamy appearance. This can be done by looking under the oil fill cap (However condensation in the crankcase can cause this as well) or draining the oil just to be sure.
A compression and leak down test should also help you in determining if there is a head gasket issue.
Well checked the radiator top and bottom and can not see anything that would resemble a leak like yours tblume. Took the plate off from under neath and dry down there.
spdwaver I have not done a pressure test how would I do that?
Oil looks normal, I think I am going to order an analysis.
That's what I meant, “The top pinch area”. If it's a small leak (which mine was) it only happens when the system is fully pressurized and the leaking coolant would evaporate before it could be detected. I detected my leak one day after a drive. I had the hood open and saw the mist of evaporating coolant.
That's what I meant, “The top pitch area”. If it's a small leak (which mine was) it only happens when the system is fully pressurized and the leaking coolant would evaporate before it could be detected. I detected my leak one day after a drive. I had the hood open and saw the mist of evaporating coolant.
Ha ok then after a long drive I should give it a check. I was looking at it after it had been sitting for a couple hours.
Note-when I went to the dealership for the coolant, the guy said that because of the toyota red I am using a leak would be very distinguished. Plus he said to pull the number six spark plug and see if my cylinder was clean. If so then the fluid is cleaning it and that is an obvious problem.
Alright pulled the #6 and #5 spark plug and looked down into the cylinder. Found that the top of the cylinder had build on it. Spent sometime underneath near the six piston looking and the headgasket and all looks well. Inspecting the block for any signs of cracking, nothing there. Plus inspected the radiator after a long drive and could not see anything coming out, top or bottom. Didn't have time for the compression test but will try that later. Have not lost any fluid since refilling two days ago. Even smelled the exhaust and it smells like it always has like a little rich, but that could be due to my CEL and code 25 and 26.
Just curious how you inspected your oil?
Ummm.... Since you had someone else do the PHH, it doesn't sound like you tore down the head overnight. How did you inspect the head gasket? It isn't really a direct-view item.
The reason people are saying to inspect your oil and plugs is to see if there are secondary signs of a common type of internal head gasket failure. It happened to both of my '96s on the back PS corner of #6 between a coolant and oil galley. Not visible from the outside.
How did I know they were bad?
On my wife's truck, I changed the oil. There was a bubbly red film on top of it and it was 1/2 gallon down in the radiator with a dry overflow. We changed it out at my brother-in-law's place. Since I got lucky and found it early, there wasn't much damage and it was hard to see on the head - but it was there. The gasket had been 'scrubbing' a bit and left a bit of a shiny wear spot on the head where the mixing had started.
On my truck, there were no signs of it. When my wife's truck's HG went, I already had the parts on hand to do a supercharger for mine and had planned to do a preemptive head gasket job so I wouldn't have to remove the SC later. She got my new head gasket and I ordered another one. Well, we tore mine down and sure enough - it was a good idea. It wasn't as bad yet, but it had just started to scrub in the exact same place.
Two head gaskets inside a month and a half. I'm pretty convinced that all FZJ80 head gaskets will eventually fail.
What would help here is if you could post up pictures.
1. The end of the spark plugs from #6 #5 and maybe #2 so we have a baseline for the wear.
2. If you have a borescope camera (unlikely), pics through the spark plug holes of the cylinder tops can show discoloration if coolant has been getting in that far.
3. Change your oil using an open catch pan. Take a picture of the oil sitting in the pan with STRONG lights or sunlight on it from a low angle so we can see if there is coolant on top.
4. Pull your radiator cap, flip it over and snap a picture of the back of it. Is there foam?
5. Can you see the exhaust? I.e. is it white clouds? Does it smell sweet?
6. If you want to take the guess work out of it, send an oil sample to Blackstone Labs. They will tell you if there is coolant in it.
All of this just helps diagnose the problem. If you do have a head gasket failure, it isn't impossible to do at home, but its quite a bit harder than a PHH. The idea is to confirm or deny if it is this. You could still just have a coolant leak in a hard to see place. There are a few hoses up behind the catalytic converter that connect to the rear heater that can leak - the hard lines for the rear heater are known to corrode and leak - you could even have a leak in one of the heater cores, but you'd likely smell that and not be able to see out the window.
So, its all about narrowing down the possibilities. If you already tore down the engine to be able to make a direct determination on the head gasket - then you're already changing it. As far as I know, they are not re-usable.
IMHO YMMV I am not a mechanic.
Sorry I inspected it the best with out a tear down just looking for obvious signs.
Have not drained my oil yet but will soon and hopefully not to late.
No smoke from the exhaust, but you description of a gallon low and nothing in the over flow is exactely where I began.
Checking the oil through the dipstick once again looking for obvious signs. My oil is clean without any tinge of red.
I got under neath and removed the dirt cover from the wheel well just like you would to to the PHH and just looked for cracks, anything coming out from there, but as you said it could be failing on the inside.
