Spent sometime underneath near the six piston looking and the headgasket and all looks well.
Ummm.... Since you had someone else do the PHH, it doesn't sound like you tore down the head overnight. How did you inspect the head gasket? It isn't really a direct-view item.
The reason people are saying to inspect your oil and plugs is to see if there are secondary signs of a common type of internal head gasket failure. It happened to both of my '96s on the back PS corner of #6 between a coolant and oil galley. Not visible from the outside.
How did I know they were bad?
On my wife's truck, I changed the oil. There was a bubbly red film on top of it and it was 1/2 gallon down in the radiator with a dry overflow. We changed it out at my brother-in-law's place. Since I got lucky and found it early, there wasn't much damage and it was hard to see on the head - but it was there. The gasket had been 'scrubbing' a bit and left a bit of a shiny wear spot on the head where the mixing had started.
On my truck, there were no signs of it. When my wife's truck's HG went, I already had the parts on hand to do a supercharger for mine and had planned to do a preemptive head gasket job so I wouldn't have to remove the SC later. She got my new head gasket and I ordered another one. Well, we tore mine down and sure enough - it was a good idea. It wasn't as bad yet, but it had just started to scrub in the exact same place.
Two head gaskets inside a month and a half. I'm pretty convinced that all FZJ80 head gaskets will eventually fail.
What would help here is if you could post up pictures.
1. The end of the spark plugs from #6 #5 and maybe #2 so we have a baseline for the wear.
2. If you have a borescope camera (unlikely), pics through the spark plug holes of the cylinder tops can show discoloration if coolant has been getting in that far.
3. Change your oil using an open catch pan. Take a picture of the oil sitting in the pan with STRONG lights or sunlight on it from a low angle so we can see if there is coolant on top.
4. Pull your radiator cap, flip it over and snap a picture of the back of it. Is there foam?
5. Can you see the exhaust? I.e. is it white clouds? Does it smell sweet?
6. If you want to take the guess work out of it, send an oil sample to Blackstone Labs. They will tell you if there is coolant in it.
All of this just helps diagnose the problem. If you do have a head gasket failure, it isn't impossible to do at home, but its quite a bit harder than a PHH. The idea is to confirm or deny if it is this. You could still just have a coolant leak in a hard to see place. There are a few hoses up behind the catalytic converter that connect to the rear heater that can leak - the hard lines for the rear heater are known to corrode and leak - you could even have a leak in one of the heater cores, but you'd likely smell that and not be able to see out the window.
So, its all about narrowing down the possibilities. If you already tore down the engine to be able to make a direct determination on the head gasket - then you're already changing it. As far as I know, they are not re-usable.
IMHO YMMV I am not a mechanic.
