I've seen pics of what seems to be a center console organizer that drops into the lower section next to the CD changer (see attachment). I've searched the internet and can't seem to find a part number or supplier.
Not sure if this helps. But I am turning the center console into my power station. I will take apart the power inverter casing and I will be using some simple ABS plastic as the face place and cover to mount USB/110/andUSB-C to this 58806-60051 area and rear outside of the center console. This way everything stays in one spot and can be tucked away. I will use the Victory 4x4 console molle panel to basically hang everything on clips and my ORS molle panel. Ram mount laptop mount attached to the passenger seat rail.Is there an organizer that is designed without the CD changer? Mine is just a big hole and it’s a big mess in there.
58823-60030 Is the correct part #Here is the part number 58806-60050 or 58806-60051. Now finding it is a matter of luck because it's discontinued. Check amayama.
58823-60030 is the part # your looking forI've seen pics of what seems to be a center console organizer that drops into the lower section next to the CD changer (see attachment). I've searched the internet and can't seem to find a part number or supplier. View attachment 3140983
Also not discontinued, Pheonix PDC warehouse shows 5. After those 5 are sold then it'll most likely be discontinuedHere is the part number 58806-60050 or 58806-60051. Now finding it is a matter of luck because it's discontinued. Check amayama.
Yes @BenCC has a make but I am not sure if he is active on here anymoreIs there an organizer that is designed without the CD changer? Mine is just a big hole and it’s a big mess in there.
forum.ih8mud.com
