Wheels on front axle tilted in on the bottom of tire
SoCal
Hello all! I’ve searched here and online but have not come up with anything, but putting a chain on the axle and bending it up. The front of my vehicles front tires are pointed in on the bottom as you can see in the two pictures. The third is my rear axle tire. I used a dirty driveway to show the tracking on the tires. I have replaced all bearings, bolts, seals and brake parts, everything. It should be brand new. 95 percent is factory OEM Toyota. Any idea what I did wrong or how I can adjust it? Thank you in advance for any help!!!
Lucas
Do you have like a dry wall square - put it next to the wheels perpendicular and see it the tires/rim are square to the earth.
I’ll give it a try. Thank you!
Looks like mine - they run 1 degree or so of camber
It could be. I have never had an axle with all new parts. Maybe it is the way they were built new.
30 psi. What would you suggest for non Offroad driving
I would drop a few PSI and then roll through that dust again and see what it looks like.
Someone above mentioned 26lbs so he might be on the money.
Sounds like a plan! I’ll give it a try.
