wheel spacers
Vancouver, BC
Fact or Myth? Do wheel spacers cause premature wear on wheel bearings and drive components on an 80? What is the recommended spacer width, that will give the advantage of a wider track, and minimize wear?
thanks, g
Fact or myth... that will be the question for the ages... I think this is one of those topics that will never be fully understood. In my many years of playing with these toys, I'm convinced that 1" wheel spacers really dont have much of a long term effect on the bearings. Being that, some have had problems, others havent. HOwever, the ones that had, it could be argued that the maintenance on thier bearings could have been lack luster to begin with.
Bearings are wear parts. They need maintenance. Only thing I would say, get them if you want. Just keep an eye on your bearings and service them regularly if not more than regular. You should have no ill effects from simply keeping them in good shape.
Is that an answer? :D
The best width is up to you. Based on what I've read over the past few months 1.25" is about the most common followed by 1" an 1.5". I plan on doing spacers for a slightly wider and more stable stance but don't actually like the look of 1.5" spacers and am on the fence with the 1.25". I will ultimately do 1" but remember you can pretty much only do 1" with OEM wheels as the factory studs protrude beyond the spacer from what I've read and the stock wheels just so happen to have hollow spots between the stud holes. You should search around, you'll see pics that should help you decide. Hope I haven't further confused you.
You need to look at wheel adapters as opposed to wheel spacers. FWIW. I am running 1" wheel adapters and like the added width and seeming stability.
I have 1.25" wheel adapters (you could go wider but then the tires would stick outside of the fenders - yuk) with stock alloy wheels. I check the torque often, but I have never had to tighten mine.
They help counter the lift for handling, stability, and looks.
1.5" final decision
Thank you for the thoughts gents. I ended up going with 1.5" wheel adapters. Pushed the wheels out enough for the tread to align with the fender flairs. Aside from the aesthetics, the vehicle does feel a little more stable. An unexpected benefit.
Now to get reading up on bearing maintenance. Cheers...
