wheel question for my FJ62
has anyone put these on your FJ60/62? will they work? pictures? thanks in advance for your help
Google tells me that those are either 16" or 17" in diameter, 7" wide, with an offset of +4mm. That gives you a backspacing of almost 4", whereas the stock wheels have a backspacing that's closer to 3" (6" wide rim with an offset of -12 or -15mm if i recall).
All that to say: you'll probably need a spacer to clear the tie rod ends at full lock.
Yes. The 62 I bought from @Elkwagn had those in there, with spacers.
I've since moved to 80s axles, so no more spacers. But yeah, spacers.
I have those wheels on my 200. Yours look fantastic!
Time to change my Avatar! Haven't paid any attention to it, but realized Idaho Savage has owned it since 2017!! Anyhow this is my wifes 60 I just finished an LS swap into, and as you can see it has those same wheels, with a spacer and 285/75 BFG's. Also a pic of them on my 80, with 37's. Once the weather permits I will wash it and take new pics for my avatar with it next to my 80
What size spacer did you run? Thank you
