I'm thinking of moving on to a 70 series and so the 42 will likely go. Looking for collective IH8MUD wisdom to help come up with a fair asking price and hoping to sell it to someone here.
Full disclosure…I made the terrible mistake of buying this from Vintage Offroad, before discovering IH8MUD. Due to my naiveté and lack of intelligence it should go without saying I lost some money on this one. Mechanically it's very sound but it needs a sh*t ton of sheet metal work or an easy 3/4 Aqualu tub. I daily drove this for the last 5-6 years and it could continue to do so. I believe the mileage to be accurate at 258,000ish km but who knows.
Specs:
THE GOOD
-November 1983 build date JDM BJ42, 24V, RHD
-3b w/ aftermarket turbo from Diesel42 just installed (dropped oil pan for return line, blasted, primed and painted and resealed with OEM pan gasket--bottom end looked good with clean oil and NOTHING else)
-Amaurer's updated gauge cluster with new mechanical oil pressure and water temp gauges and ammeter gauge along with EL wire (still working out a grounding issue)
-Aftermarket Isspro pyrometer, boost gauges (still working on wiring)
-Compression on all cylinders mid-400s
-New glow plugs (super glow system)
-Rebuilt rotary IP (no EDIC) as well as injectors by certified Denso shop
-Cooling system just overhauled with rebuilt OEM radiator, new heater valve, hoses (t-stat already replaced a few years ago)
-New OEM/Aisin clutch master and slave cylinders and brake master cylinder within the last few years.
-Front discs, rear drums (need servicing)
-4 speed
-Factory A/C, power steering
-31 x 10.5 BFG AT w/ ~50% tread on stock steelies (including spare)
-24V-12V solar converter
-CCOT HFS front bumper
Things that would/could be included in the sale would be an H55 from an '85 BJ73 that had ~250,000km on it, bought from a member here. Also have Mopdog's aftermarket but OEMish diesel tachometer (not installed). Paki soft top bows and Paki grey vinyl bikini top. Real steel OEMish bolt on tailgate. Toyota FSMs. A few other little bits and pieces (Marlin inner seals, some weather stripping, extra oil pan)
THE BAD
-The body (see pics)
-Needs new rear crossmember and diagonals, maybe frame rails from hangers back but can't really tell without taking a wire wheel to it, or blasting (rest of frame is solid with surface rust)
-Needs brake and knuckle servicing
-Leaf springs are TIRED, could use a nice OME lift
-Front axle housing may be slightly bent as evidenced by my difficulty with getting birfield in and out when servicing and reappearance of leaking knuckle
And now the pics...
Specs:
THE GOOD
-4 speed
THE BAD
And now the pics...
