What year is this 2F?
Check the driver's side of the block towards the front. If it has been threaded for power steering brackets I would say its a 79+
Its definately 79 or later, I'm not sure if it was tapped or not. I haven't paid that much attn., I wrote down the #s hoping to look at sor's faq and no luck.
Hummm, Do you know if the carb is original to the motor. If so the carb number would indicate a build date and that would get you in the ball park of the motor. Happen to have the frame number the engine came out of?
Engine story...Motor came from Spaceghost. Toyota dealer called him up and said a lady has a 2F motor in her garage and needed it gone. SG went over there to get it. Lady said her son pulled it for a V8 about 8 years ago b/c he had to have one. The son said it ran great and was worth $1000. I don't know what he ended up paying for it. It is pretty much all complete except fan/fanclutch. SG definately said it was a 79 or later but wasn't sure exactly what year. Hopefully it runs
phishtaco said:
Yes I already checked Spector, numbers don't go this high.
2F424881
Would this be a carb #, only one I really saw 648X ? or 9L26 ?
Ok, i may have my head up my butt on this one but I have a guess as to your year. If you look at SOR's FAQ page with the numbers for 1978 you will see that each month of prouction starts with 2F - 23**** etc. Each month that number increases by one (roughly). 12 /78 has the number 2F-33*****. Since yours is 2F-42***** that would make yours approximately sept. 79. give or take a month.
Just a guess.
Bob
pulled from a 40 or a 60?
is the side plate dented for the big cap dizzy? if so its a 8/80+
2F424881
Would this be a carb #, only one I really saw 9L26?
Marty,
The carb number translates as 1979 December 26th.
The date code is cast in the block on the manifold side, midway between the last two core plugs.
It is a 5 digit number.
First digit is the year.
Next two digits are the month.
Last two digits are the day of the month.
So your block might have a number like 91217
9= 1979
12= December
17= the 17th
Will somebody put this info in the tech section so I don't have to type it again? :crybaby:
Will somebody send me a platinum membership so I can attach pictures to these posts? :grinpimp:
zetasig said:
Marty, are you getting the number off the block casting? Should be down on the passenger side just below the side cover. Flat spot on the block.
I'm not a real Marty, but I play one on TV. :)
He's getting the SERIAL number off the serial number pad.
The block casting number is on the Left side of the block. It is a typical 10 digit Toyota number, something like 10011-61013.
