Here is my question--I have a mostly stock 1972 FJ55. The only real mod from stock are lifted springs. I have been given a completely stock 1982 FJ60 with a blown engine. I was trying to figure what I could usefully salvage from the 60 to upgrade the 55.
Some of my preliminary thoughts:
* 4speed w/ transfer case: I recall reading that the 70s 4 speeds are more easily adaptable. What is the limitation here?
* Axles: My understanding is the 60 axles are wider and can provide a more stable stance, but some support tabs would have to be welded to the frame to widen the position of the springs.
* disc brake knuckles: If I don't move the entire axle, at least transplanting the knuckles with the disc brakes would be a good idea.
* diff/ring/pinion: if I don't replace the entire axles, the r/p on the 60 (3.70 right?) will be better matched to the 4speed ratios than the 4.11s on the 55.
* power steering: can the FJ60 power steering parts be transplanted to the 55 easily? What is involved?
* engine: like I said it's dead, but the engine on my 55 isn't like new, so, if I were to do a rebuild, the 2F would make a better platform.
* seats; maybe--they're in ugly shape, but ugly bench vs. ugly bucket, ugly bucket wins.
Any thoughts on the above items or anything else I should consider?
thanks,
Geof
thanks,
Geof
