Reviving an old but good thread here.
Why does everybody put a suspension upgrade up so high on the priority list?
(Honest question here, not trying to be an askhole (to borrow a term from @AnyMal))
I ask this because my home CFO allows me one large expenditure a year for my camping/overlanding.
This thread convinced me that I need a fridge.
Opinions on fridges - https://forum.ih8mud.com/threads/opinions-on-fridges.1313113/
But now I’m contemplating which I should do this year. Suspension or fridge. I’ll do the other next year.
And fridges are hardly mentioned in this thread here discussing the order for mods.
Am I wrong in looking at both as nice-to-have’s that make trips a little more comfortable?
And yes, 2” more ground clearance would offer a safety benifit along with comfort. I don’t discount that.
But my usage is more in line with @Itsky. I’m not interested in rock-crawling. It’s more camping and getting to trail heads. So wouldn’t the main gain for me just be in comfort on the dirt roads?
Or is it that this thread is more about “modifications” and a fridge doesn’t count as that?
I’m contemplating it from a money spending/ wife allowing perspective.
I think a lot of it has to do with attitudes and looks. A stock 200-series, in LC or LX flavor, is more capable than most drivers are... but that doesn't look cool, and it doesn't set you apart from the crowd. Big tires and a lift make any truck look cooler than stock, even if they actually make the thing less capable offroad if done poorly.
A fridge doesn't look cool, and no one can see it, so why spend $2k on that when you could make your truck look cooler?
I would say do the mods that you know you will use, and then address anything that follows. For example, if putting in a fridge eventually leads to installing some drawers that you keep filled with heavy stuff you will start to bottom the rear suspension. So that would then justify some suspension mods. Or if in your use you're legitimately running out of clearance, adding taller tires and an appropriate lift would be justified.
in OZ most vehicles are limited to tires that are (depending on state) +-50mm diameter from stock, and roof heights that are something like +-50mm from stock otherwise they need to have a licensed engineer test/inspect/placard the vehicle to certify it as road safe. These laws are much more actively enforced than anything in the US, and a fixit ticket immediately suspends the vehicle registration until it is fixed and inspected. So down here fridges, awnings, drawers, solar, etc are all common mods and are considered to be a "real" modification. 35" tires are considered to be a "big" tire.
