What offset for 285/75/17 wheels on 99 LX 470?
Sounds like +25 is going to be the go for most aftermarket choices.
Hi all, I appreciate your inquiries regarding our wheels.
We did make an error in the design on fitting the +35mm offset on the 100 series. We apologize for this error and want to make it right. For this year, we are looking to do a +25mm offset for the 5x150 platform and we are looking to release these in Q2.
Please feel free to reach out to me if you have any questions.
Just giving you a heads up, I'm planning on wheels this spring and your Command wheels are my top pick as of now. I love that you're not using fake beadlocks and that you offer a variety of offsets. I'll be keeping a close eye out for 100 series updates.
Command wheels are on. Slight Ahc sensor lift completed. Pinch weld mod completed. Still has a slight rub on the plastic wheel liner in the front. I’m using 1” Bora spacers on front wheels only. No spacers on rear right now. I’m considering having the wheels machines so they don’t need the spacers. Have not tried tucking the wheels yet.
Thanks for the update. I went with Evo Corse (17x8, +40). 10 week wait. I’ll update when they arrive in another month or so.
The Command wheels look good! With the +35 and 1” spacer, you should be at about +10 offset right now. Does that sound right? How did mount & balance go? I can’t see well in the photo, did you go with dual stems? Please post a photo to show how much they push out, also a closer shot of mounted wheels for others’ reference. Look great, thanks a lot!
Was the spacer to clear the center cap? And I am assuming these are 17 with +35? wouldn't +35 be a better option for 100 series than +25 (as they mentioned they are looking at putting out Q2)?
I love the Evo Corse wheels. One of the best looking wheels in my opinion. If my math is correct then yes, I am at +10 offset for the front wheels and +35 for the rear wheels right now. Mount and balance went well and I did go with dual valve stems.
I’m not sure why some photos are rotating?
The spacer is so the wheel itself will fit over the hub bolts. In the photo below you can see how the wheel will fit until the hub bolts hit the first part of the bore where it gets narrow. Yes they are 17” with +35 offset. The desired offset is up for debate but I think a +25 or +35 offset is perfect for this 8” wide wheel with 285/75/17 tires. The photo below shows my rear tires at +35 (no spacers).
That's a great size. I had ST Maxxs in that size for a couple years. Not too much rubbing. I would go with a +25 personally, as I think it looks better and you don't have to worry about contact with the UCA. My wheels are 17x8.5 +27 so you can get an idea:
What’s the poke?
