What is this?
Breckenridge, CO
Its essentially between the oil filter and pan behind the oil pump/ cover. I am leaking oil from above this piece I believe. Ive done a little research, but am on the road with limited time and internet connections. Im hoping that if I can get the name I can find a pic/ diagram of the top to see where the leak may be coming from and apply some sealant for a temp fix.
Thanks all!
I just rebuilt my pump with a Gates rebuild kit. My pump was leaking from multiple locations but mostly from the rear housing (in the red box)
Yeap. Happens all the time. I purchased a reman from my local autostore. It just wasn't worth the hassle to me. The steering box on the other hand is quite pricey and easy to rebuild.
But the wrenching is the fun part...
a RHD brand new genuine steering box for my 80 would cost well over A$2000, and if I wanted a 105 series later style one I'm up for about A$3000. That's just for the box before I get the special pitman arm for it. That's why I'm working through all the other bits of the physical side of the steering system first.
Thanks all!
That looks like a recently replaced pump? If the fluid is leaking quickly, pouring out, possibly the bore plug has fallen out? This is a common problem with "re-builder" pumps, likely because they oven/heat clean them, loosening the plug.
We made it to CO and are getting settled in.
Thanks all for the replies!
We made it to Colorado but man did I dump a ton of oil into the truck. Im talking like a quart every 100mi. My wife drove it until the light came on then I added.
Ive taken it to both OTRAMM and Iron Pig back on the east coast and they think the leak is somewhere around the oil pump/ cover. However, neither seemed too jazzed to work on it. To me it seems like it's leaking on top in the vicinity of the seam between the oil pump and power steering pump. Even with a flex camera it's next to impossible to see.
The truck doesnt need to be my DD any longer so I may dig into this a little more myself. If I cant make any headway I may just take it to Slee or some other shop here along the Front Range.
Thanks for the suggestion. I dont know what a bore plug is but will look into it. Im certainly losing a lot of oil when running.
Ive had the truck for 4+ years and the pump was not replaced during my ownership. I actually suspect that the leak was present when I bought it but it has gotten progressively worse over the years. Is it just the cleanliness that makes you think it's "new"? I cleaned everything pretty well before and during the trip to get a better sense of where the leak is originating.
Thanks man.
I could be wrong but I dont think it's the PSP thats leaking. I would assume that the PSP would be leaking PS fluid and I am most def leaking motor oil.
Thanks man.
Correct. If it's leaking a qt every 100mi, it's huge mess, where is the mess pouring out?
Best I can tell it's along the top of the oil pump/ oil pump cover/ PSP. Its the oddest thing. The mess I see just doent look like it's a quart even considering a lot of it may get blown out when driving at highway speed. Having lived in the city for many years I havent been able to work on cars so Im no expert but I would think there would be a huge mess as well.
It usually leaks out tbe back. I ended up buying a seal kit with bearing from camelback toyota, was like 68 bucks i think. Took me 1/2 an hour and ive never touched one before. 15 minutes to get it off the truck and 20 to get it back on and filled. Its a two banana job. Pretty damn easy.
If you were leaking that much, it would be a huge mess, like rear axle, tailgate covered, puddles when parked after a drive, etc, type of mess.
Out the back of which? =-)
Yeah thats what I would think. I have some oil on the parts in my main photo (bottom of PSP, that nut, where you can see some sealant smeared on, some on the oil filter, the 2 gray tubes). I have a few spots after parking it after a drive no puddle. Both OTRAMM and Iron Pig seemed a little baffled as well. I dunno. Maybe I take it to another mechanic and 3rd time's a charm.
Maybe start by removing the power steering pump Then reinstall it with a new pump to block o-ring. No p/s pump rebuild or anything. Just simply a new seal to the block. You can get that o-ring from your Stealership. See what that does for you.
