What is this?
Maybe start by removing the power steering pump Then reinstall it with a new pump to block o-ring. No p/s pump rebuild or anything. Just simply a new seal to the block. You can get that o-ring from your Stealership. See what that does for you.
Sounds like that could be a good start. Thanks-
If yours is the truck I think it is, it was weeping between the timing cover and block above the oil pump cover and power steering pump. It was the sealer joint between the two as opposed the either of the o-rings.
Hey Ryan! You may have it right. Dustin, with the white LC from Maryland? Brought it down a couple times - once before and once after the new shop opened. I hope all is well! Ive been watching some of your videos lately.
I just moved and am between homes so dont have access to my invoices. Thanks for clarifying the issue. The leak has gotten worse and it seems that it's time for me to get it taken care of. Am I correct to assume this is a job for an actual LC mechanic not something that I or a general mechanic should tackle?
Thanks again for chiming in!
Yeah thats what I would think. I have some oil on the parts in my main photo (bottom of PSP, that nut, where you can see some sealant smeared on, some on the oil filter, the 2 gray tubes). I have a few spots after parking it after a drive no puddle. Both OTRAMM and Iron Pig seemed a little baffled as well. I dunno. Maybe I take it to another mechanic and 3rd time's a charm.
A quart every 100 miles is a big leak, has to be going somewhere. Your single picture doesn't show anything that would be close to that. The quote of a weep is normally something that would be hard to detect on the dip stick after thousands of miles? That type of leak would literally be dripping off of most of the undercarriage.
If it's not, the only conclusion is it's being burned. The first check on that path is; PCV, breather system, clogged or otherwise ineffective? With the cats in working order, it's sometimes hard to tell, but is it smoking?
Yep, yours is the one I was thinking of then. Not sure how a leak from where we saw it would do a quart in 100 miles. You may have spring an additional leak or you're burning it. The leak we noted would require the timing cover coming off to get resealed. Not a super difficult job but time consuming by the time you get the oil pans off.
Thats what I thought. I dont have a lot of experience but I figured that much oil would make a larger mess. That photo above is AFTER I wiped it down well, but still. On the trip out here it would smoke heavily when stepping on the gas to get up to highway speed after an oil fill up stop. =-) However I had added some Lucas (I know, maybe not the best idea but I was desperate) to the oil in the hopes it would slow the leak and apparently a side effect is excessive smoke. I dont recall ever noticing smoke back in MD before heading out on the road trip.
By "cats" I assume you mean catalytic converter? I noticed a new noise a month or so before leaving ad while I havent nailed it down it sounds like its coming from the PS mid way back.
I have a buddy coming into town this weekend but I'll do a little research on the things you mentioned to check. Previously being a city guy with no garage and the LC being my DD Im not very knowledgeable about cars. I'll see what I can dig up here on MUD. Im assuming that the things you mention I can check on myself?
Is it possible that I could be getting an erroneous reading from the dipstick? We would stop when the oil level light came on. I would check the oil and it would be low. However, there was often the slightest oil line along one edge of the stick well above the "full" mark.
Is this the same spot?
On the way out here Id clean the leaks up as best I could, add oil, drive until the oil level light came on. I d stick my finger in the gap where im pointing to and there would be a good amount of oil on my finger. Generally there would also be oil covering most of the items in the photo from my original post.
That gap is where we saw it weeping while it was at the shop. It's the joint between the block and timing cover.
Thanks a bunch Ryan. Really appreciate you chiming in and confirming!
