You will pull those off that leaves two plac s on the manifold that is what you will block off with plates you make or buy then all those tubes will be gone your truck will run fineWhat about the stainless tubes going to manifold?
Thanks for the replies! I’m still
Scratching my head as to why someone would put a 94 engine in a 97.
So I guess it’s no big deal. Both are pretty much the same?
Roger that.That is just a plastic plate that bolts on.
Does it have a crank position sensor? If it really is a 93-94 engine it shouldn’t. Maybe it’s just the head that’s been swapped.
Yeh the port works, my check engine light came on a few weeks ago and I had a guy at the local Toyota stealership run a diagnostic and it come up as a EGR code.It may have one if they swapped the timing cover. This way it would work with OBD2.
OP: Does your OBD2 port work?
