What is this sound?
Oxfordshire
1994 LC that drives well, but recently developed this sound. It sounds like air sputtering, not metallic ticking. Thoughts?
Ok, that make's sense thanks. Any thoughts on how to isolate where the leak is?
well check to see if you can see where carbon is escaping from the system (like black soot leaking out)
then if not...wait until the exhaust is cold and you can spray it with soapy water, start it then look for bubbles...
...someone else might have more input but you can try that.
Will try the soapy water technique thanks!
You can also tape a shop vac hose to the exhaust tip, with the shop vac hose on the exhaust of the shop vac (instead of the suck side) and turn it on to create a pressure in the exhaust and it will remain cool the entire time you do the soap bubble test. You will hear air come out the intake, as there will be one set of valves open.
Odds are the leak is where the down pipes connect to the manifold. Looks like you've had exhaust work done and aftermarket gaskets are known to not seal well there.
To add to the list of ideas here I've had luck with:
-with a cool engine/exhaust​
-mostly or partially block the tailpipe with a rolled up rag, chunk of foam or similar. Use something that will just blow out of the tailpipe if pressure get's too high. If you have a helper they can just hold something over the tailpipe on request while you feel for leaks.​
-then with the engine idling, crawl around to listen for the leak​
-place your hand around any areas that may be leaking, a few inches away from any suspected leaks should work and allow for burn avoidance​
-where there are leaks you should feel puffs of warm air on your hand​
A subtle leak will be more pronounced with the exhaust partially blocked to increase back pressure. I'd start by checking any welds or junctions around the cats, based on where the noise is of course. The 02 sensors could also be leaking, etc.
As loud as that is I’m sure you can find it by carefully running your hand around those new exhaust joints with the truck running. You’ll feel the air pulses. You’ll pin point it in seconds.
What brand are those cats?
