what is this sensor?
I have a VERY slight leak around a sensor and want to replace the gasket. From under the truck on my 1994 it is on the driver side, mounter on the block right over the bottom of the block near the oil pan. Angled down like it is reading the motor oil from the pan. I figure it might be the oil level sensor? Held in by 4 10mm bolts. On the side of the block with no other sensors around. I figure it should be easy to identify even with out a picture. Any ideas?
cool. That is what i thought. I guess the larger "bell" shaped thing on the other side behind the AC compressor is the oil pressure sender, right?
It is hardly a leak. The motor is super dry but has a good pit of Moab dust on it. Around the sensor i can see a black is damp area. no drips but messy bolts.
It's the RC51KID needs to stop asking so many questions and fix the leak sensor!
