What is this plug for?
San Juan Puerto Rico
Website
www.facebook.com
While doing an oil change on my daughter's 80 I noticed this plug against the firewall that reads "Diagnostics". What is it for?:hhmm:
My US spec 1993 80 series has it as well.
I know you have to jumper two points in there if you're advancing your timing.
Is a 1992, US Specs.
T1 and TE1 IIrc are jumpered to put in base timing (no advance)
Also can retrieve codes there if check engine light on. (counting of check engine light blinks)
I don't know if it counts as OBD1 but it was the precursor to the OBD II plugs in everything from 96' on.
The dealers have electronics that hook up there.
That is a proprietary Diagnostics connector, it can serve several functions. You can use a paper clip to jumper a couple of pins and retrieve any stored fault codes in the engine ECU. It's not OBD-I. You can also jumper the +B and Fp terminals and it will force the fuel pump to run.
OBD-II didn't really see total roll out till the '96 models. The standard connector is always inside under the dash, the US-spec requires that it be within 3' of the driver, so it's usually down near the steering column.
So... it is for connecting some type of scanner that only the Toyota gods have at the stealership?:hhmm:
The older Toyota scanner does have a connector that can be used on that "DLC 1" connector. The data stream is limited and sometimes non-existant. (Edit: Sorry for the repeat info, typed & stepped away) The tests listed above are available as well as connections like VF1 & VF2 for Oxygen Sensor testing.
