What is this carb part and where do I get one?
Connecticut
It's time to deal with the carb on my 1984 '60, because I've got high idle, bucking, running rich, and all the other signs of trouble. I've got a rebuilt carb to swap on, but the part circled in the photo has a rotten rubber boot, and I'd like to replace it before I swap carbs (we're looking at the carb. from the driver's side).
I've had little luck figuring it out from the diagrams I have, and the local Toyota people have never seen one of these.
Whatever this part is, it doesn't seem to be critical-- the one currently on the cruiser also has a rotten rubber boot, and since it was dripping fuel onto the exhaust manifold, I had to remove the linkage and seal it off. But this is kind of lame, and it would be nice to fix it for real.
Any pointers about how to deal with this part? Dripping fuel down onto the exhaust manifold is something I'd like to avoid.....
Thanks!
Many Thanks! I will check out Larry Miller-- I've got a bunch of PO receipts from them. Seems like there is an endless number of small bits and pieces to hunt down and deal with.....since everything old around here rusted away long ago, not many mechanics around here are much help.
That's why this forum is so invaluable...
Thanks for the info about the jet valve. I've had no luck at Larry Miller or Specter sourcing one, so I'm sticking with the one I've got, with the lever removed and the top covered in sealant. That's stopped the leaking gas, though I suppose it means I won't be screaming past anybody without that extra jet.......
