What Is This Bracket? Newb Question
WYLIE TX
I Have A 1978 Fj 40 That I Thnk Is Turning Out To Be A Franken Fj....after Purchasing I Realized A I Have A Fiberglass Top.....dont Know If Thats Good Or Bad. I Am Trying To Figure Out What This Bracket Is For And The Two Holes On The Engine Block Are. I Still Have This Mysterious Oil Leak That I Think Is Orginating Somewhere In The Manifolds... You Can See Where The Oil Is Dripping Down.....this Photo Was Taken After The Engine Cooled... It Drips Out Pretty Bad Right Where The Two unknown bolt holes are. And it is not the valve cover that is leaking..... i think the bracket is for power steering, if it is this isnt a 78 engine is it?....opinions And Suggestions Welcome
The engine in my 40, is an '84 2f. Should be very similar. In that location is the air pump for the smog equipment. On S-O-R there are some good diagrams of what belongs where on these engines. Do some research there, and you should find most of the answers to your questions.
By fiberglass top, do you mean the whole entire top is fiberglass, as in the panels with the windows in them, or just the top portion, that was white in color originally. The top piece, with the headliner attached to it, and bolted to the sides with bolts you can feel there just under the roof is supposed to be fiberglass. That is stock, good or bad, I don't know, it reduces top weight, so the vehicle is a tad bit less top heavy. But the top can be damaged easily, and the original metal raingutter was rivited to the fiberglass and will leak over time.
As for the bracket you show. On 1F engines which were used up until late 1974/early 75 that was the bracket for the alternator, or at least very similar to it. After 75 the 2F engine was put in and the alternator is mounted high on the other side of the engine. However the smog pump, or air pump, whatever you want to call it was mounted down low on the drivers side for the emmisions system. Yours looks to be gone, as is most of the emmisions stuff I assume. The bracket can be removed if you wish. It bolts on with the two bolts you can see there, and should just slide out from under the engine mount.
Factory Power Steering was only an option on the FJ-40, and would have had its own bracket bolted to the side of the block above the area referenced in your picture. The bracket bolted on with three bolts in a similar fashion to the alternator bracket on the other side of the engine.
As for the oil leak, not sure. There isn't any oil in the manifold area of the block. The head is fed oil pressure by a small copper line that ties directly into the rocker arm shaft. There is a main oi galley that runs the length of the block on the this side of the engine. It is the bulged area above the two mystery holes. But a severe crack in the block would be the only thing to let it leak. It may still be the valve cover. The two hole may have held the EGR bracket cooler thing on, they are just there, they should have a bottom to them, try a piece of wire in them, they should just be tapped holes.
My valve cover just recently started leaking. The 2F cover has a rubber gasket, mine simply cracked and split in one spot and now leaks oil. You may not see the oil running down the side of the head, as the heat shiled under the carb makes it difficult to see that area of the valve cover.
smog pump bracket..
oil coming out of those holes is od tho..
GOt a bigger pic of the engine?
Oil is probably from a leaky/weepy valve cover gasket like MoConative said. If either of those bosses had a hole or crack in them you see a steady stream of oil, their low(er) points where the oil collects as it drips down the block.
Is your rocker cover steel or aluminum?
If it is steel, it is likely distorted from being over-tightened, and will not likely seal properly again. Check the condition of the cover and the gasket, as it is likely leaking on the manifold side of the engine, and down the side of the block….something could be preventing it from sealing properly as well…I have seen covers that had wires in-between the head and the cover gasket causing the leak.
If it is an aluminum cover, again verify the condition of the gasket and the sealing surface, as it could be something simple.
Brackets:
Top:
F engine alt bracket
Middle:
2F engine smog pump bracket
Bottom:
F engine smog pump bracket(attaches to pass side cylinder head)
The removable bracket on the left side of the motor mount is where the air pump was mounted. The two threaded bosses in the block on the right side of the motor mount is where the EGR cooler box was mounted.
my alternator is on the other side up top....the leak is not coming out of the smog pump holes, that is where the oil globs are landing. i was running the motor and just watching, about every 10 - 20 seconds a large drip of oil would land right there above the openings. When I am driving it mists out and lands on my exhaust pipe......smoking on the outside of the pipe....here are some more pics
Remove the air cleaner and run the engine.....watch the cover and take note where the oil is comming from...
Tuck the camera down by the inner fender, or lay under the driver side of the engine looking up and take a couple pictures of the underside of the intake and exhaust manifold trying to focus on the area that the oil is....
