What is it worth
the gimpey one said:
sold the factory carb today. So how do i test the smog pump to know if it is good? Next on the chopping block hopefully.
Spin it and shake it. When the stuff falls out of it you will know its shot.
so if nothing falls out it is good?
well here is to hoping!
Just tear it apart, takes about 30 min to rebuild...only two bearings is a national 204 and then Marshall has the other number written on his table so he'll have to post it up.
I would send pully with it anyway.
If you going to see if it's good you have to open it up. In order to tale it apart you need to pull the inner pulley off. Check and make sure the blades are intact. That is what they care about. Spector wants a rebuildable core.
