That's cool. Here's how I did mine. Used one of the sunvisor type remotes with 3 buttons and installed in my ashtray. double side taped to a small platform welded to the inner part of the ashtray.
Opus what kind of tires are those and what's the size? I have those exact rims and I am trying to figure out what tire will work best.got some new shoes.....View attachment 1118135
and spruced up some parts for the 65 refresh...
Hanook MT...31 x10.5x15Opus what kind of tires are those and what's the size? I have those exact rims and I am trying to figure out what tire will work best.
Drag link is sad.View attachment 1128200
This past weekend... I finally finished my scout power steering install. Just a few clean up things and the fender can go back on..
View attachment 1128331 View attachment 1128332
What Pittman arm did you use? Center to center length? Drop? I have a Scout box to put on sometime, but have held off until I can replace the long stock arm.
Don
I used a drop pitman arm for a 78 Jeep Wagoneer . Here is the link for it. http://www.amazon.com/77-79-5-Bronco-74-91-Wagoneer-Pitman/dp/B0091W5GSO/?tag=ihco-20
And the tie rod I used was a Moog PN: ES453L
Drilled the steering knuckle plug to install a permanent Zerk grease fitting.
Center punched to guide the drill bit (13/64th bit)
Used a little jig to hold the plug for drilling
Used a 13/64 drill bit
Successfully drilled plug
Next to tap the hole, used a 6mm X 1.00 tap
Tapped the Zerk fitting hole while using plenty of cutting oil
Zerk fitting installed
A little paint and ready to install
Great idea Mike.
I think I'll copy that (except I'll probably use a smaller straight nipple/zerk rather than that larger angled type).
I don't think that area of the knuckle is supposed to have grease. I could be wrong, but I can't think of why grease would be needed their. The only areas that make contact are the trunion bearings right?Drilled the steering knuckle plug to install a permanent Zerk grease fitting.
