Here's a pic of those pesky light bulb shields in a 55 gauge...Here you can see the light-blocker things you need to remove if you want to see your needle at night.
View attachment 492332View attachment 492333
Step one is disconnect the battery.
I knew something was missing!Thanks! I'm going to have to remove some parts to get in there with a proper torque wrench!I just looked up the torque for that about 30 minutes ago! View attachment 4133689
I’m going through steering now and always fear losing steering.
I got my center arm rebuild and reinstalled with new hardware and got my steering box set on the mount. Waiting on parts to complete my front / steering rebuild/ replace/ refresh.
I was able to get in there from above with my smaller torque wrench without much trouble just a few hours ago. Good luck!Thanks! I'm going to have to remove some parts to get in there with a proper torque wrench!
I learned that battery disconnect trick in 1974. The first time the sparks flew I jumped of the seat.Step one is disconnect the battery.
I drill a ⅜" or so hole in the end of that dome your Phillips is pointing atGood thought Charlie…but I did try a few other thoughts I had and here is a run-down: do the bulbs actually work?…YES. Where is the voltage NOT getting to? It is going to the terminals in the cluster housing and receptacles. Now I measured the metal shield that @Buffchief said he had drilled a hole in.. 20 mm deep… took the cluster apart, been a while I can only assume and cleaned everything. Had I some orange paint, I would have dressed the needle indicators..but no, so next time.
View attachment 4135332View attachment 4135334View attachment 4135336View attachment 4135338
After every thing I had tried, I am guessing the 22mm length of the bulb assembly is preventing the brass contact tabs on the receptacles from making contact after I had unfurled the short wires on the bulb and touched them to the ring on the circuit board. That worked. So it sort of confirms my thinking that the brass contacts are not connecting to the ring of the circuit board and bending them upward does not work.
Since these LED HOUSINGS are plastic I had shifted the wires out of the way and ground off about 3 mm of the plastic housing and re-folded the wires back. The problem here is that the black bulb receptacle has a collar that does not allow the shortened bulb assembly to be placed deeper in the housing. Nice try but nothing. Went back to the clear stock bulb.. works fine. Re-assembled it all with bright white LED’s in the high beam indicator and both L/R directional signals
Here’s a few more photos to get an idea of where and why
View attachment 4135339View attachment 4135340View attachment 4135341View attachment 4135342View attachment 4135343
I had these new gauge face decals but decided the FJ40 cluster look fine..so, back in the box they go
Rheostat has to be full on for mine to come on. No dimming with the LEDJust a thought, LED's are directional so they don't work backwards, incandescent bulbs will work either direction of electricity flow. Try rotating the led in the holder 180. Use your meter to check polarity on the board. Turn up the rheostat on the light switch, maybe its set below the led's min voltage.
You bet. It'll work out. Little at a time@Buffchief I ordered these that you used…. Just clicked off of their site. I was actually going to slice the exposed arc at the dome about 1/3 more of a radius on each side and bend the dome slightly forward…that would expose more light and provide clearance. I just don’t know if the extra light would be too much and bleed thru the wrong areas. I have another old cluster but, it is easier to just get the smaller lamps. My luck, the dremel would grab…spin down across the face, zip across one of the gauges…or worse. I can also have a few days to get some florescent orange needle paint for those pointers
Thank you for the reference![]()
