I'd run dual relays regardless. It helps a ton for both brightness and safety, I'd think.
I severely crashed my '74 about 5 years back. So bad I could only part it. Bent middle of frame bad. Went airborne off a river bank at (45 mph?) and landed it square on a Boulder half the size of the vehicle. Quickest stop it ever made! It was destroyed.
I added these on my 40 last month. I replaced some hummer 24v headlights the PO installed that used a 12v to 24v converter. It was a very easy installation and the difference in light is remarkable. The low beams are brighter and wider than I got out of the high beams before. The high beams now are unreal. This was by far the best upgrade I have made to the 40. For $130 it was money well spent. You will be amazed at the light. I didn't add relays but probably not a bad idea if you feel they are needed.Did you have to upgrade the relay or works with existing relay?
Existing works fine. Truly plug and play. From what I remember, these were even easier than swapping out the headlights on a newer JK I had a few years back. Super smooth install.Did you have to upgrade the relay or works with existing relay?
I used the exact same battery in mine, nice! As for what I did this week, like a lot of you, I took it on the longest drive so far for Christmas last Sunday. Drove to Gatesville, about 180 miles one way. 30 minutes in it developed a strange oscillating vibration, I figured it was coming from the drive shaft. I pulled over and everything seemed normal, so I kept going. By the end of the trip it had just fixed itselfInstalled a new Toyota battery!
That is one beautiful rig you have. Wow! You guys have driveways just like mine! I just keep needing another inch of lift every few years.Aired down my tires so i could make it up the driveway.
Very talented work. Super nice!!!Installed newly refurbished 4 speed transmission hump cover. What a wrestling match to get the cover installed. The welding fixes changed the shape making it challenging to install. For anyone wanting to upgrade from a j30 to H42, I highly recommend it.
Also installed new fuel filter with OEM bracket, changed oil and installed OEM hand brake firewall floor grommet and hold down bracket.
What makes the paint like that. The textured look.
