What have you done to your 200 Series this week?
will those fit with the 3rd row installed? very nice looking!!
I decided to get a baseline on the rig before it gets modified this week. Needless to say I found the limit of the factory tires and low factory clearance when I got it stuck in a mud hole. Luckly my buddy in his 100 had no problem tugging me out. :) Had a great time and can't wait to go back with some must needed modifications. I'll keep y'all posted!!
Public service announcement.
Check your KDSS valve often for corrosion.
This part is raw iron from the factory. Mine was frozen shut and I was replaced under warranty. Almost $2500.
I suggest you remove the cover, fire brush it and back off the set screws 3 turns and coat liberally with anti seize or your favorite lube.
here is what it looked like a year after being replaced and again after I tended to it today.
Hi, nice done but did u ever tried zinc coating, with that kind of corrosion i think it will work out.
Have a link to to that finish or are you recommending removing and plating?
Out of curiosity, did you try using CRAWL Control to get out?
TIA
With the road oriented factory tires, I don't think Crawl would have done anything in that type of mud.
"Thinking" what might have happenned to someone else is very different than hearing directly whether it was tried. But thanks for your "thoughts" anyway. :confused:
Just that something similar happened to me with the OEM tires, Crawl did nothing. Tried it later when I changed my tires, went thru the mud OK.
Something similar happenned to me with the OEM tires, CRAWL worked!
Since blackoutz was "establishing a baseline" for his stock 200, I think it would be helpful to find out if he considered CRAWL one of the tools available to him in the situation he found himself, and if he tried it. As a new owner, I can easily imagine it was overlooked.
I am often surprised by the capabilities of CRAWL - even moreso now that I have some decent tires.
HTH
I began to use it once I got stuck, the problem was the ruts were too deep and didn't have the clearence to keep moving. Instead I was just pushing mud until eventually I dug myself in. If I would have had my lift and 33's on im very confident the craw control would have worked like a charm :)
TIA[/QUOTE
Went to a locally owned and ran exhaust shop today. I'm ready to address the stock unit that hangs low below my rear high clearance bumper (which is not attached in this photo).
Anywho - any exhaust experts in here want to kick some knowledge my way on what I might ask for? Stainless - ok
Muffler - or not?
Thanks
Went to a locally owned and ran exhaust shop today. I'm ready to address the stock unit that hangs low below my rear high clearance bumper (which is not attached in this photo). View attachment 1165113
Muffler - or not?
Thanks
I put a straight pipe instead of that end tip using stainless and pained flat black.
Get them to cut off the tip start up the cruiser, cycle through the rpm range and you should see if there's any change in exhaust note or vibration. That way you could choose whether to put on a resonator or not
Muffler - or not?
Thanks
I'll be interested in what you find out here... for obvious reasons. On my 100 I had the same situation and after tearing off my resonator at Tellico and not seeing any adverse affects from not having it on, put a pipe in. Works fine on the 100. Hoping for the same with the 200.
