Some pump until the first movement of the shaft before grease spills out. YmmvUsually when you grease a joint like this you pump the grease in until you see it start to come out the sides. That grease then gets flung off over time...it can both make a mess and help to rust proof everything around it![]()
haha, yep you caught me!ps: wasn't sure what arvo meant, searched; Australian slang for afternoon??
You wipe it off!?beandle: Clean that area off with a rag or paper towels, don't over grease the slip yolks, just a few pumps, stop if/when you see the shaft start to push out (and use a Moly fortified grease).
If you pump until you see grease coming out around the slip yolk shaft you have likely overgreased it (unless the seal is worn), so then you can remove the zerk fitting (?8mm socket) and let any excess come out, then replace the zerk.
For the U-joints, which caused some of that mess, you do want to continue pumping grease until all the air (and/or water) and old grease has come out of all the end caps.
What I like to do to decrease the mess is after greasing the U-joints is to use my fingers to get in and around the spider (U-joint) to remove any excess grease that has spewed out so it doesn't get flung around.
FWIW
Well, thats fine for the U-joints, but not the spline - not such a good idea in this case - Like @Kernal and @bigredmachine said - be careful NOT to fill it up with grease.Usually when you grease a joint like this you pump the grease in until you see it start to come out the sides.
Good point. My mind was in pin and cv mode.Well, thats fine for the U-joints, but not the spline - not such a good idea in this case - Like @Kernal and @bigredmachine said - be careful NOT to fill it up with grease.
Think of it as a giant hypodermic syringe - if you fill it up with grease (an incomprehensible fluid) then it becomes a fixed length column between the diff at one end and the transfer case output shaft on the other - now what happens as you go over bumps? LOTS of stress!
If you want to grease the hell out of it, then remove the zerk after - slide it shorter - to push the excess grease out, then replace the zirk, leaving some compressible air space inside.
