What goes here
Redding, CA
Taking a little closer look at the 1978 California model that I bought a few months ago and discovered a few questions. This vehicle DID pass smog as is. Trying to figure out what if anything connects to these and where the connection goes from there. I have placed the ? marks above the suspected connection areas. I have one other area but am having a little problem taking a picture, it's the silver aluminum (kinda like a smaller clothes dryer exhaust) that hooks to the air cleaner inlet at one end and just lays(on mine) near the exhaust manifold at the other end. Thanks!
First picture is air pump intake. Should be a rubber hose from there to the top of the air filter.
Second picture is carb cooling fan. Nothing goes there. It just blows air at the carb and intake/exhaust manifold.
The metal hose from the air cleaner is supposed to connect to an insulated cover that goes over the front of the exhaust manifold. It collects warm air off of the exhaust manifold to help the engine run better when cold. I don't think the CA insulator is available any longer. I have a new one that I can sell, if you are interested.
Look at piece 30-FT in the 76-79 California view.
http://www.sor.com/sor/cat044.tam?xax=23752&page.ctx=cat044.tam
Ther are two hoses that are connected the upper most hose in the picture is connected at the other end to the top of the air cleaner. So, either it is connected to the wrong thing or there should be two hoses from the air pump connected to the air cleaner(although I don't see any other connect points) If it is connected incorrectly then where does the one that is connected go??? Still puzzled....
I'm sorry. I screwed up. The lower hose in the top photo should go to the top of the air cleaner. The upper hose in the top photo should go to the ABV on the fender, and then a hose from the ABV should go to your air rail.
The fitting in question is like a relief. There is no hose attached there.
I just had to run outside to take a look because I haven't seen it in awhile.
I PM'd you
