Hi,
I have a 83 BJ40 with a B engine. I am in the process of installing a Turbo on this engine. Although it is probably not recommended considering the B doesn´t have piston skirt oil cooling, I´m going ahead cause tha B is pretty gutless. Eventually I plan to install a larger, maybe a 14B engine with this same turbo once the B blows up
Knowing this, what gears do you recommend me running in the difs. Considering i want to run 33 or maybe 34" tires?
By the way Its got the stock 4 speed with splitcase transfercase.
I was debating between 4.56 and 4.88. Would 4.88 be too high a gear for freeway speeds, that is 55-65MPH?
Thanks.
. Knowing this, what gears do you recommend me running in the difs. Considering i want to run 33 or maybe 34" tires?
Thanks.
