What gauges do you use
San Jose, CA
I setup my cruser with Autometer and after finding incorrect gauses, gauges that stick, gauges that don't work at all, I'm done with autometer.
What are all of you using? I'm thinking of moving to the Stewart Warner Maximum Performance Series http://www.sw-performance.com/products/products.aspx?productcategoryid=Featured
Oh, and has anyone used those electronic speedometers with an FJ? Sounds like a good idea.
Thanks, Scott
Thanks, Scott
I just installed a sunpro tach II so far so good it's kind of large 3-1/2"
but I got it on ebay for $12 it works well assuming it is correct :-)
hmmm, I have 3 Autometer gauges in my cruiser, all work perfect.
Have installed and used Autometer products for many, many years.
Pro-Comp series 2-5/8" or 2-1/16".....Street tachs, and many others.
Have not had an issue with any of them.
What series are you using?
-Steve
Same here, used Autometer for years. Always considered them to be high end quality gauges. Interested in which ones youre using too.... :confused:
-Steve
I'm using the Phantom series (white back, red pointer, green light).
I've has 3 clocks (first one stopped working, the second one didn't tell the correct time, and the current one the spinner to set the time stays engaged all the time so the second hand moves but minutes an hours don't)
The mechanical temp gauge sticks at 100 until the engine gets to about 160 and then jumps.
The volt gauge says I'm running 16v but when I check it with 3 different multi-meters I'm between 14.2 and 14.8v.
The vacuum gauge sticks and doesn't move smoothly.
A few of the red pointers are now faded. Interesting since they all get hit with the same amount of sun but only some of the pointers are faded.
Well you can see why I've had it with autometer.
What do people think of Stewart Warner? I used to use them back in the day and I think I remember being happy with them.
Scott
AlaskanWheeler said:
Did you purchase your gauges used? I've used Autometer for a long time with no problems
Nope. Bought them all brand new.
I've used Isspro gauges. They are OEM for some of the truck manufacturers. I've had no issues with mine.
My rig came with a pod of Stewart Warner electric gauges (temp, oil pressure and volt), and only the voltmeter was accurate. I swapped them out for Autometer ultra lites.
Sorry, but the Autometers have worked great for me.
Good luck.
ive been using the autometer carbon fiber series gauges in my cruiser for about 4 months and they work perfectly. not sure about the phantom series though... i use 3 stewart warner gauges in my other cruiser and have had 'em for a year. 2 of them work fine but the oil pressure gauge sticks. im thinking of swappin' 'em out for the autometer sport-comp series gauges. if i were you, i'd try my luck at buying autometer gauges again and seeing if they work. they worked for me
good luck
i have 6 autometer gauges in my '40, no hitches in any. well, i did have a problem with the fuel mixture gauge, but that turned out to be the O2 sensor, not the gauge. i wonder if it is just the phantom series... i dont think i have ever seen anybody using them. but all the other autometer guys i have spoken that run non-phantom gauges love them. maybe it is time to change models!
e
I just put in an Autometer mechanical temp guage. "Calibrated" it in some boiling water before I installed it. Wasn't dead on, but now I know where the error is and it's been pretty consistent so far.
Most guages should be treated as a trend detector rather than getting hung up on numbers. If your engine is intially running well, put in the gauge set and note what they read at various loads and speeds. This will be "normal" for your engine.
If things read to high or low from normal, it's time to start troubleshooting.
I'd also recommend VDO. That's what I have in my other vehicles and you can really go crazy monitoring stuff. (Radiator pressure guage?? :confused: )
I'm another satisfied Autometer user. 5 gauges in the 40 to supplement the stock gauges. Tach, vac, oil pressure, water temp, and volts. These are in the Z-series line. Have had these in for 4 years with no problems
