So, I have a new to me 96 and it has 217k.
GOOD
Front End rebuild -100 miles ago, new front shafts since they were chewed up too
Front & Rear new rotors and pads - 100 miles ago
power steering being rebuilt right now
BAD
Rear Diff, transfer and transmission fluids all need to be changed
Rear Main Seal leaking
Valve Cover Leaking (head gasket if I understand this right.....right?)
Master and Booster could be swapped out.
Now first, the engine. The local shop has put the bill at about $1100 to do both the rear and the cover. Now, with 217k is this a smart move or do I run it and just get a new/rebuilt motor. I notice SOR sells the motors for 5k roughly and I can check with Man-a-fre or other sources you suggest. Or is this overkill? If I do the rebuilt it will be in spring. I figure I can get one more winter out of it since I need the truck due to snow. Or do I just do the seals and be done with it for some time. I don't plan to get a used motor because if I am going into the trouble of pulling the motor it will just be rebuilt. I just hate to put 1100 into it just to pull it apart soon after.
The fluids I plan to do as money permits. I have not looked at it, but the rear I can change myself I think if I am correct. (I have done it on jeeps before)
The trans and transfer case, is it better to take to a shop or is this a diy? If diy, rough cost figures vs shops doing the work?
Like I said, my main focus is the engine. But should I leave it alone and do the fluids first? Etc?
GOOD
BAD
