What does this plug go to?
Georgia Tech
Chasing down a short that has been blowing the brake light fuse. It is the Green/Red wire going to the three conductor plug in my hand in the picture. What is this plug meant for?
Well I decided to look at the wiring diagram one more time after posting- it is the plug for the horn relay. I have no idea why I removed the horn relay years ago, might explain why they haven’t worked and also means I get to keep pulling apart the harness behind the dash to find the other end of this smoked wire towards the fuse block.
If you find the issue is with the fuse box, maybe this is an option:
Thanks guys. I wasn't too clear with my post- I actually already have a new fuse block installed.
I meant that I have found the short, but now I need to trace the burnt wire back to the source of current so I can replace all of the compromised wire.
Your 1974 FJ40 has the brake lights and horn on the same fuse. So if the GR wire going to your horn relay connector is melted the short is in that wire and not the GW wire for the brake lights.
