What do I have? 40 newb
And I got extended reach lug nuts to be on the safe side. 19mm head
I’ve been picking up used parts off the mud classifieds.
I’ve got all the rest heater components other than the heater itself.
And @Vulcan sent me a pile of cluster/ dash goodies
Happy to not have any cracks and hopefully a speedometer that’s more accurate.
I went ahead and put led lights in as well as touched up the needle paint.
Lost about 47,000 miles on the swap. I looked at correcting the mileage. However didn’t have the patience to spin the speedometer for hours.
If you find yourself needing another project (riiiiight), it’s pretty easy to disassemble, clean and grease the odometer wheels and put them back in whatever order you want. In the few I’ve done, the grease gets hard and the 1/10’s, miles and 10’s place spin freely but then would stick when it comes time to turn a 100’s or 1000’s place wheel.
I looked at this. Decided I was going to break things with my bear hands and decided to stop.
Ooh can’t wait to see these on.
@Skreddy I’ve done this to odometers yrs back… what kind of grease are you using? Is it light stuff? I’d like to try the one in that interval timer under the hood
I used a really light lithium I think? Super lube brand. And I didn’t use much of it at all. Also used an electrical contact cleaner to clean all the parts so it wouldn’t eat the plastic or finish on the wheels.
Good call. Even rubbing alcohol will disrupt the paint/ink on the tumblers.
Well I have two more ready for tires.. Ole black and decker drill made it through one more project. I really should replace it, it’s given me concern for a couple years. I’ve got all the wheels drilled. Just need to tap the last two and install clips.
My back hurts. I should have done this on the work bench, not my 3 year olds chair.
It’s like having another gear. In every gear.
But I bet 4 low isn’t low enough now. That’s ok. I’m mall crawler
4lo in 1st will still change the speed of the earth’s rotation I bet.
The Fifteen 52’s open the door on a lot of choices.. IMHO, your stance looks great too.
