Got the coilovers removed to get heavier duty icon springs swapped on. Went ahead and changed oem front bump stops for timbren.
Got my coilovers back with HD springs swapped on: awesome!
Got home and found this bolt had been sheared:View attachment 3348619View attachment 3348620
Icon is closed. So I cant call them until tomorrow.
stupid question: does this bolt bear any force from the coilover springs, or does it simply hold the upper mount in place?
Would this bolt have been messed with to swap the spring out?
Anyone happen to know the size of the bolt? Looks like icon makes it custom.
lfdoffroad.com
Red!! That is a stupendous idea.. I will get some and an insert tool.I used rivnuts for my mount. Not hard to install and allows threaded inserts to be installed anywhere in sheetmetal.
Home made compressor bracket. Stainless steel plate, 3 bolts, rubber inserts. Bolts right in, in front of the air filter housing.Today I worked on mounting a passenger side ARB pump mount.
ARB Compressor Mount - 5th Gen 4Runner and GX460
Constructed of .120 304 Stainless Steel, our Air Compressor Mount allows you to install an air compressor in your engine bay. On board air is useful for airing back up tires after off road trips, powering air lockers, or even running air tools. Installs easily with no permanent modification to...lfdoffroad.com
Its just unbelievable to me NO ONE makes this mount for our GXs
I caught one threaded hole on the bottom almost below the filter housing. Made a metal strap and caught another hole top rear.
Now I'm going to do a mighty self tapper and catch outboard forward front, I don't want to get inside the fender and put a nut. Took me a couple weeks to dream it up but looks like it's going to work.
Now I need to begin dreaming up how to hook up to the Switch Pro.. Then airline out to the front bumper.
