Hilux Timing belt, water pump, idler pullies and accessory belts, seals, new hoses, thermostat, 12 Blade fan, viscous coupling, fluids etc etc.
1KZ timing belt job. Got love doing it with Toyota wrenches.View attachment 3522679
Nice!fabricated a custom mount and installed an astra electric power steering pump. Now just need to plumb and wire it and then I will have power steering without the parasitic drag of a normal belt driven pump.
Thanks. I will have to step it down to 12v.Nice!
Does the pump run on 24v or are you going to step it down?
Some fresh snow at the pallisades dam. Did some fishing on Friday.
Today I did some winter undercoating of the frame and underside of my buddies' rig. Good wash, some coats of CRC-06026, and fill all holes, nooks, crannies with fluid film. All three of us drove our hiluxes so I captured the moment:
yes, crush washers for the spill rail have failed it seems, they are aluminum, follow torque spec, it could be the injector crush washers though too, but less probabilityfired up the old 60 thats been sitting a while. started up fine. Had previously noticed it was a bit more sensitive to glow time and stumbled and smoked if i didn't glow a lot (and after glow). so figured start with checking the basics.
decided to do a compression test since I'd never checked it in the 16 years I've owned the truck.
#1 400
#2 385
#3 360
#4 390
Redid #3 and got the same reading. then slight increase with a small spray of oil for wet test (375). So not a great result given the spread highest to lowest. right around 10% lower on that cylinder. disappointing not quite bad enough that I feel a need to do much about it yet. Will check valve lash. think its been about 100k. Then just run it this summer if all goes well.
Other observations. All the glow plugs came out looking similar. #2 injector is a bit greasy i presume from fuel leakage. Wouldn't hurt to deal with that as well i suppose.
out with all the other tractors haha!My turbocharged b in cold weather is a devil to get glowed correct.
We took him for a fun ride tonight. It is in the 50s here in Illinois.
My BJ 73 arrived in Montana today, can't wait to get home and drive it.
Looking forward to hearing how the truck runs after install, I’m due and looking at the same setPulled injectors; waiting on delivery today from Australia. Remanufactured injectors by HiTech Diesel in Adelaide.
1 HD-T Injectors
Once I return old injectors, cost works out to be $140 each.
