What did you do on your 70 series today?
Today I started to do the suspension bushes on my troopy ,forgot how hard it can be on your own.
Got the front done and now I'm recuperating for a few weeks while I contemplate the rear.
I always wondered why the previous owner left a box of polyurethane bushes and some greasable pins in there when I bought it. It was ok for a while and then all hell broke loose.
Thanks. I had 20 done, used one and gave Steve Jackson 2 so I have 17 left and listed them in the jdm/diesel parts section for sale
Very nice!
Not much to report today, updated the design of my din slot switch panel to recess the switches like in an oe dash. Ordered two from shapeways to confirm it works.
Wired up my second fuse and relay box, hope to get it mounted this weekend.
Got a little time to work on the girl;
Installed Solar Converter to balance batteries and act as a 12v Power Source (truck is 24v). Need to make custom brackets to hold loom
Installed new fuse block for 12v system. I chose the back of the glovebox as I plan on having this thing out where the floorboards and kicks may get covered. It sits flat and will be easy to keep the wiring clean and access it here. I made the main power feed and ground easy to disconnect for removal if I need to access behind it, all wires are coded. I need to figure out how I am going to get switched power in to the lower section of the block since all switched power is 24 v and I am not sure a 12v Relay will hold up
Installed Stereo/navigation system
Installed 12v power Source for phones (cigarette lighter)
New resistor for blower motor
Getting better all the time
Some axle work....
Some transmission and transfer case work:
So are you moving axles? I know the front can be moved by drilling the perch, but not seen anyone moving
the rear. Looks nice and cleaned up, curious as to which shop your truck is in. Not familiar with who is in
Atlanta.
Atlanta.
I am not in ATL currently.
The SF rear axle housing (came stock on my JDM BJ70) had different spring perch spacing vs. the FF rear axle housing I retro fitted.
The difference was different enough to damage my spring pins as well as destroy bushings at a fast rate considering the off set at the shackles. Also wallowed out the perches so that the springs were actually moving on the perches. No Bueno.
We used Ruff Stuff perches and corrected the spacing differential to line up the springs correctly.
Installed:
