got the insulation finished. all doors all sides. floor is next.
Nice, I'd like to do the same. Do you do the reinstall yourself?I started the process of window tinting. pulled the window, tinted, new channel molding and painted the frame. 1 down and 3 to go.
yes, I have not "glued" the window in yet. It is held by pinch weld for now. I am going to clear coat the paint with poppy's patina. Ultimately i will reinstall the windows myself.Nice, I'd like to do the same. Do you do the reinstall yourself?
What insulation is this?got the insulation finished. all doors all sides. floor is next.
Chinese. 10mm. If it’s not enough, I will either stuff it with wool or put another layer on it.What insulation is this?
Have you used that stuff before?I am going to clear coat the paint with poppy's patina
Never used it before. Looks like a winner. I will post picsHave you used that stuff before?
I never heard of it before.
Looks like a good solution for my Hijet.
What is the small cylinder attached to the main filler neck ( parallel ) ?
Sending positive vibes for a smooth r&r of the tank. Ratchet straps really do help. As do positive vibes.
Maybe God knows. Maybe not.What is the small cylinder attached to the main filler neck ( parallel ) ?
I'm about to do mine as well. What rookie mistakes if you don't mind sharing?Spent about 15 hours in my dirt driveway swapping the original suspension for the OME kit. Things actually came apart pretty easy, much easier than my FJ62, but still a long long job. And I still made a few rookie mistakes just to make sure it didn't go too smooth. Bushings were actually in great condition on the inside despite being cracked around the edge. Old shocks were absolutely toast, completely useless. So the ride is now much better.
Basic stuff like winging it and not reading the assembly diagrams on the OME hardwareI'm about to do mine as well. What rookie mistakes if you don't mind sharing?
Ha ha, sounds like stuff I do regularly!Basic stuff like winging it and not reading the assembly diagrams on the OME hardware
And make sure what you're installing goes on the side you're actually working on front or back.
The procedure is the almost exactly the same as the FJ62 instructions found here: FJ62 - Old Man Emu Installation - Detailed Steps - https://forum.ih8mud.com/threads/fj62-old-man-emu-installation-detailed-steps.1125788/
I added some notes in that thread from when I did mine a few years ago and just updated them.
