- Thread starter
- #21
Is there a harness that could be bumped by the shifter assembly ie: if there were a short in a harness that somehow sent a ? power spike to a component in the tach?? Sounds impossible but in the video everytime you shifted into Reverse the tach dropped out, curious what could connect those two things??
I pulled the whole console and looked for anything out of place around the gear shifter and indicator assembly, and nothing was frayed, or remotely odd. Same goes for the loom to the cluster itself. Cluster flex board was also triple-checked for any broken traces, shorts, and nada. The cluster does share a common ground for many of the different parts, and that is one area which I thought could be a path for a problem.
So far the new tach shows no signs whatsoever of the odd behavior. Time will certainly tell.
Steve
