Went shopping today
Western Slope, CO
Went to get some steel to do my sliders and came across this outside the building. Turns out the guy did all the work to the axle mini disc conversion, hy-steer, SOA, and then decided to go with full width axles. So I see it sitting there and ask him what he wants for it. So being the cheap sob that I am offered him 100$ for it... :D Well damn if he didn't jump on it, guess I should have offered him 50$ huh. anyway shot some pics real quick...
What should I use to get the rust off the rotors, the perches look like they could use some work too...a little bead on each side holding them on. Hope it has 4.11s too, so what do you guys think? I paid too much?
Aren't the highsteer arms worth a hundy?
Looks like a great dea lto me.
'Grats!
Ed
take em off and have them turned
Send the entire assembly to me at your expense and I will remove all rust, paint, determine ratio try out for an undisclosed period of time and later return to you at again, your expense. I hate smartarse posts like mine!
Seriously though, good snag. We're all entitled to one snag like this every so often. I'd go through the knuckles, clean/inspect everything. If it truely was converted with minitruck it is possible, but unlikely this would have been done to a post 09/75 axle as I understand this was the date Toyota switched from front drums. You can also mount the axle in your truck when the knuckles are removed and use an angle finder across the top trunion bearing race to measure the caster angle. This will tell you if the knuckles were cut and turned and what geometry you have.
I have always found that driving a rig does the best job of removing rust from rotors :flipoff2:
Good score :)
So I guess I should look into a SR before putting this axle underneath huh? Damn things are getting better everyday! I might have a 2F from the same guy too
