- Joined
- Mar 8, 2009
- Threads
- 20
- Messages
- 124
I always buy the non chlorinated brake cleaner, is this any better? I will not be using it for finding leaks again but just courious.
I think the article is somewhere between hype and BS. Somebody will sic Snopes on this one sooner or later.
We use a lot of TCE at work and it is very stable and very volatile. While it could conceivably break down in an arc plasma, the main thing it will do is evaporate. It is so volatile it will be gone before you strike an arc. It is extremely unlikely to break down to phaosgene in a MIG or TIG arc because there is no oxygen. It will primarly break down to HCl or hydrochloric acid, which isn't particularly toxic. Even if it did make phosgene, the amount would be so small that it would be hard to detect let alone have a toxic effect. The label on the can is just some lawyer covering their asses. You won't find anything about those claims in the MSDS (material safety data sheet).
The testimonial may be true, but it is not related to phosgene exposure. You would have an immediate reaction, not one 9 days later. I think he had a hangover.
It sounds like you are saying that you use brake cleaner when you weld and you are ok using it and nothing will happen?
