- Joined
- Feb 16, 2011
- Threads
- 16
- Messages
- 146
Sorry if discussed but couldn't find it...kinda weird to me that these giant bolts protrude into the wheel well and aren't covered? I don't remember these from my 2016?
My 08 does not have those.
Possible (probable?) that regulations mandate the bolt protruding past the threaded portion of the welded nut a certain amount for full strength, and in the event the bolt starts to back out.
As for why there, seatbelt location for safety probably trumps all kinds of other design objectives.. like having a bolt protruding into the wheel arch area. As an example of regulations dictating stuff like this.. check the thread size/pitch. These are probably not metric threads. I know on my 80 the 3rd row upper belt anchors can be replaced with 7/16 fine thread eye bolts for one end of a hammock setup.
I can't understand why it bothers people.. why grind? There is a TON of room for chains/cables to clear. You'd be hitting mud flaps well before that bolt. By cutting you risk messing up the threads in the weld-nut if you ever pull the bolt out. If anything I'd say use fluid film or LPS3 to prevent corrosion and just ignore it.
What I’m curious about is...why do some 2008’s not have it and others do. That part is weird indeed. Not bad or a problem...but weird is a good word.![]()
I think those that don’t see it are looking for the rear seat belt bolt in the front wheel well.
