I've had the same issue intermittently for quite some time now. Good news is, (in my case at least) it wasn't a rod-bearing issue. Sorry for the long winded response, alot of context involved in my situation, lol.
My 268k 1FZ has always been noisy, but this noise really freaked me out when it first started. One super cold morning, (10-15*F) I cranked the 80 and it made a loud piston slap noise. Immediately shut it off. Cranked it later that morning after tossing some Lucas in the oil and the piston-slap noise was still audible, but not as loud. I thought the 15w40 Rotella I've always run was to thick for the December climate, so I threw on a new OEM oil filter and switched to 10w30. Sifted through the old oil for at least an hour only to come up with 3-4 metal shavings the size of salt granules. I never could confirm they were from the Cruiser or one of my other cars at the time. After a day or so of driving around running 10w30 I started to notice the noise in your video. I parked the truck and it sat for a few weeks. I finally couldn't take it anymore, the 80 wouldn't fit in my tiny garage, and I wasn't about to swap bearings in a foot of snow in the complex parking lot either... Towed my rig to my old shop in Wheat Ridge (Toyota Specialist shop, well versed with Cruisers) and had them check things out for me while I was out of town for work. My old service writer calls and tells me, bearings even at 241k (at the time) were perfect. Pulled upper/lower pans, valve and timing cover. Only found black-plastic chunks in my upper pan. Timing chain, tensioners, and everything inside the head was unscathed. While it was torn down, I had them swap my perfect original bearings out with new OEM bearings for peace of mind. I was out of town the entire time they had my rig, so I never saw the black-plastic shards.
We came to the conclusion that the PO had broken the old oil cap and pieces fell down into the oil-pan. Eventually a piece positioned it's self to where it was blocking the oil pick-up causing an intermittent oil-starvation. Cleaned pan, fresh rod-bearings, no random engine noise... I was content for the time-being. I eventually got sick of how much oil my 1FZ burned running 5w30. Switched to 10w30 for a cycle then back to 15w40. Every oil change over the last 25k + miles has been free of metal shavings. The noise came back in the last 5-6k miles, almost unnoticeable at first and got to the point where it's as noisy as yours, but hasn't gotten any louder. Oil pressure has been normal throughout, up until recently. I figured it's because I'm about due for an oil change anyway. I asked multiple Toyota/Cruiser buddies to listen to the noise, no one could put a finger on it either.
I recently asked a friend who works at very reputable Land Cruiser shop here in Atlanta and he said to re-torque my crankshaft pulley bolt, as it could have backed it's self loose slightly, improperly driving the oil pump. He suggested my destroyed exhaust, which has multiple leaks could be causing such a weird noise too. (Doubtful it's this)
So in short:
1) It's probably not a bottom-end knock
2) Try re-torquing your crankshaft pulley bolt.
3) Do you have any exhaust leaks? (still doubt this is the issue, just throwing it out there)
I'm going to shake my rig down when I change the oil this weekend. I might pull my upper/lower oil pans, timing cover and valve cover to inspect, they could use a re-seal anyway and re-torque my crank pulley bolt, and report back! Good luck, if you figure it out before I do, please shed some insight lol.
