Weird ECT issue
Hanford, Ca
Website
instagram.com
I'm having a weird ECT issue. I let my brother-in-law borrow my cruiser to take out the Pismo Dunes last week. He called me and said the check engine light came on. I ran through the questions one would ask and he checked everything out and said it was fine. He made it to the dunes just fine had a nice time and and some point the light went off. Got it home and there is a 0116 recorded on the ultragauge. I thought it was strange because the temp looked fine to me, maybe just a fluke. Well then I went up to the Sierra's around Shaver Lake this weekend and made a run into Red Lake. On the way up the mountain my ultra gauge started acting weird. It was steady around 190 and then dropped to 70 degrees for a minute, then back up to 190, then down to 65, then 190, then down to 68, then 190. It did this several times, the lowest I remember seeing it go was 42. The gauge in the dash never moved though. It was stuck right there in the middle. So I'm trying to figure out where the problem night be. Is it the sensor or the sender or both? Do I really need to take all the crap off the motor to change either of those out? It's in a very inconvenient spot. Could I just be Ultragauge? Not sure where to start on this one.
If it's the sender why didn't the dash gauge move? Do you have another UltraGuage you can borrow to try it out?
Rule #1: Don't loan out your 80! Especially to family! :flipoff2:
I dunno. No I don't but everything else on that Ultra works like a charm so I doubt it's that.
I laid some very firm ground rules and he was prepared to suffer the consequences.
Gotta be some kind of wiring/ground issue, right?! When my sender went bad it just went. No signal at all. Granted I have a 3FE so I don't have all the newfangled technology of an OBDII but it doesn't make sense that it would read a temp so low then back to normal. One would think it would read normal or nothing. So, the next question is, where does the Scan Gauge get the temp from? It can't get it from the sender because the sender didn't send a signal to the dash gauge that it was cold. I'm just talking through this now. Not sure I'm helping anything...
The other alternative is, ghosts.
Crap, it might be ghost. What I was thinking, a lot of the stuff works on resistance in the electrical flow based on heat, that's why you have to test things like EGR VSV's with multimeters and such. I'm thinking this is much the same, but I've searched through the FSM and found nothing. One explanation for the dash gauge is the fact that it's a dummy gauge and has a dead zone from like 80 degrees to 275 or something where it doesn't tell you you're hot until there's steam under the hood. The short amount of time the temp fell off probably wasn't enough to allow the needle to move in the dash. I say a minute but it was probably more like 20 seconds max time it would drop off like that. Funny thing is, it didn't happen once while on the trails we were on. The hottest the rig ever got was 210.2 and that was coming into Shaver Lake after some low speed curvy road mountain driving in about 85 degrees.
Does it remain in OD when this is going on? I believe the ultra gauge gets the temp for the transmission engine temp sender signal which is a one wire green connector if I remember right.
My ultra gauge isn't picking up temp right now but I broke the Trans engine temp sender connector and have not gotten around to fixing it.
I'm also running In a fault mode that will allow OD. If the sensor is bad it might go into the same mode. But if it's working it will keep the OD off till the engine temp is about 130deg
It's prob the INTI... Same thing happened when I had it on mine... ;-p
-A
The OBD2 temp sender is different from the gauge sender. Have seen a couple of the OBD2 senders fail, both cases failed high, reading IIRC ~260F? The ones that I have seen failed, were dead, same reading all of the time, yours maybe a poor connection?
0116 does NOT mean you're overheating. It specifically means there's a problem with the diagnostic/monitoring circuit:
http://www.obd-codes.com/p0116
So this came back today. Gauge has been reading in the 67-72* range since coming off a trail earlier. It isn't jumping back and forth anymore. I'm still thinking it's the sensor. Guess it's time to pull some stuff apart.
The ECT sensor is pretty easy to remove and check with a pot of hot water and multimeter. Has been done and documented A LOT online. Your combi meter gauge gets signal from a different sender on the block, so not surprising your gauge didn't move even if the ultragauge was jumping around.
Also, you can use resistors going into the harness & plug for the ECT to check if the ultragauge is reporting what it should for a given resistance (temp) value, and jostle that wiring around to check for shorts which may explain the initial intermittent problem. You'd need to consult a FSM for resistance values in the ranges it expects to see.
Edit: make sure you use a true deep socket on the sensor. The first 19mm (I think? maybe 21) I used only had about 1.5" of hex on the inside then necked down to a cylinder.. this felt right initially but ended up breaking the plastic off the back of what turned out to be a perfectly good ECT. Also you'll need to plug the hole left by the sensor to keep coolant from spilling out. About 1/2" threaded hole.. If you leave the radiator cap on I think even a rag firmly stuffed in there would work.
Just to make sure, this has a green plug right?
